Results 1 to 2 of 2
    Default OK, So I "SOFT BRICKED" my Samsung Vitality, now what??!!
    According to the last reply I got on bricking my SS Vitality, i was told that I only "soft bricked" the device, this is evident since I can at least see the initial boot screen, and muve music logo....
    After the logo comes up the screen goes blank, and I begin to receive a series of "vibes" but thats all...
    I was told that I need to get into the bootloader/fastboot/recovery screen, and if Im correct, Ive already been there :"Samsung Recovery Utils - for BML -"
    I, "wiped data/factory reset", several times and still i cant get past the inital screen logo...
    As I said in my first post, "I think I bricked my phone 4 sure", I advised that I rooted my phone several months ago, so no problem there..., it wasnt until I loaded the "ROM Manager" & "3g/4g increase" apps. and restarted my phone, that this issue began....
    I could really use a tech-head on this one....
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default Re: OK, So I "SOFT BRICKED" my Samsung Vitality, now what??!!
    The problem is that you used ROM manager for anything. I haven't run into a Sammy phone that works with it.
    Now for the bad part. I looked quickly and a stock ROM image is not available anywhere that I can find. This kinda screws you.
    The Good news is that you sorta have a Cyanogen mod ROM that can get you back up and running.
    THe instructions are here:
    This is the only thing I have seen to help you out. Feel free to contact me if I can help
