1. trouter0523's Avatar
    I have a couple of Casio Commandos that are totalled. I have a few more with minor problems. I'd like to put together one good phone from these damaged ones.
    My question is, will a "tri-wing" screwdriver fit those four chrome plated screws on the outside of the case? If not, can someone please point me to the correct tool?
    Thank you,
    John
    05-04-2012 01:50 PM
