Results 1 to 3 of 3
    Default Red Triangle while rooting. Confused, Lost, and Nervous
    I tried to root my Nexus S but got to a point where I needed to add Superuser.exe and install from recovery and I kept messing up. Like an ***** I just quit, turned the phone off, and it's acting all screwy.
    Now I try to go back to that recovery screen so that I can finish what I started, but I get the android lying down with a red triangle above him. I looked around and see that most fixes require something having to do with something called "CMR" but I know that the root instructions I followed said the following, "This new method also installs TWRP recovery instead of ClockworkMod Recovery."
    What the hell can I do to unroot, wipe this thing, and start over??
    (Sidenote) This is the link to the instructions of rooting my phone in case it helps anyone
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default Re: Red Triangle while rooting. Confused, Lost, and Nervous
    Hello,
    First you can visit the link below to the Nexus S 4g section and you will find at the top of the page in the stickies the threads for either rooting the device or restoring back to stock. You can take your pick from there which direction you would like to head.
    Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Any questions, post them there and we will try and get you taken care of.
    Good luck
    cool. will do, thanks
