Results 1 to 3 of 3
    vw07's Avatar
    Posts
    Default Huawei Fusion
    I recently got a Huawei Fusion, I really like it. The only thing I need help on is before I update apps I have plenty of internal storage, after I update them I only have 18MB left and I cant even get all the apps updated (or even install the few apps that I want) because it tell me I have insufficient storage available. What can I do to fix this problem, or is there anything I can do? Thanks!
  2. #2
    Default Re: Huawei Fusion
    Uninstall some apps you do not use much , this will free up some storage.
    vw07's Avatar
    Posts
    I've only installed three apps, and of course I can't uninstall the apps that came with the phone.
