Results 1 to 4 of 4
    Default Plantronics BT headset issues with Media Audio
    Hi all,
    I've been using the Plantronics Voyager Pro headset with my HTC EVO 4G for more than a year now. It generally works well and the call quality is great. However, whenever the headset becomes dis-connected and I re-connect it, it re-connects to both the phone as well as to the media audio.
    I've put up with this for quite a while, but it's becoming more annoying as I always have to go into the settings and disable media audio, otherwise I miss IM alerts, e-mail alerts, etc...
    Is this common for all BT headsets? Or is it a problem with the Voyager Pro, or an issue with my EVO 4G? If one of the latter, is there a solution? It seems that once I set the option to not connect to media audio, it should stay that way unless the device becomes un-paired.
    Thanks
    David
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Plantronics BT headset issues with Media Audio
    Hmmm - that's weird. That's the way my BT works. If I de-select an option it stays de-selected. Maybe an EVO bug?
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
  3. #3
    johnshaft's Avatar
    Posts
    Global Posts
    52 Global Posts
    ROM
    Stock ROM and Kernel
    Are you using a custom ROM. If so which one? I've had some issues in the past with some ROMs and with that headset. I have since gotten the BlueAnt T1 and upgraded the firmware. No issues since.
    Nope, no custom ROMs, haven't even rooted it yet I'd like to put a custom ROM on it, but it's a corporate phone that they've provided so I guess i ought to be a little careful of what I do to it...
