Results 1 to 2 of 2
    jdragione's Avatar
    Posts
    Global Posts
    89 Global Posts
    Default Any way to do this? Reverse Call Forwarding?
    This is posted for a buddy of mine but I can't figure out how to do it so im asking you all:
    He has been an iPhone user since iPhones came out but just switched jobs and they bought him an android (Droid X2) on their corporate plan. The phone is nice but he wants to keep using his iPhone. (please dont reply bashing iPhone -- I know, I have told him many times to just use the droid)!
    Basically what he wants to do is have calls to the WORK (android) phone number go to his personal (iphone). This is easy through Verizon Wireless call forwarding. He also wants texts from his WORK (android) to go to his persona. I found an app Desk SMS which claims to do this pretty well.
    Now the question is when he want to MAKE CALLS from the iPhone he wants the calls to look like they came from the droid (which has a different number) so people do not have to put two phone numbers for him in their phone book.
    The closest I can come up with to do this is to either JB or pay for a program that spoofs a phone number but in a corporate enviornment this is not very practical. I guess he is looking for some kind of APP that can relay phone calls? And no, google voice is not an option since he wont be allowed to port that work number over to google voice.
    I doubt there is an easy solution to this, but your suggestions are much appreciated!
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Any way to do this? Reverse Call Forwarding?
    Other than using Google Voice or another VOIP number, I can't think of any way to do this. Rather then giving out his Droid number, why does he not just give out a Google Voice number?
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
