Results 1 to 2 of 2
    Froyo is yummy's Avatar
    Posts
    ROM
    Stock ROM (Froyo)
    Default Some apps won't move to as card
    Hey all I'm running android 2.2 froyo. I have installed Facebook and twitter on my phone and when I try to move them to the SD card I can't. To do this I'm using avast! Mobile security and it has an option to do so. The button "move to SD card" is blacked out for Facebook, twitter and steam. Is there anyway I can get these on my SD card? I have very little internal memory so every megabite counts. Thanks.
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Some apps won't move to as card
    Some apps can't be moved to the SD Card. Especially apps that have lot's of widgets like FB and Twitter. If it's grayed out then it can't e moved.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
