Results 1 to 4 of 4
- 05-19-2012, 08:19 PM
Thread Author #1
- 05-19-2012, 10:04 PM #2
Yes it's perfectly safe. Batteries get hot when charging.
- 05-19-2012, 10:16 PM #3
No problems with leaving it on. Was the phone in use while charging? Sometimes intensive use while charging will cause it to warm up.
Sent from my SPH-D710 using Tapatalk 2 - 05-22-2012, 11:11 AM #4
Re: Is it safe?
Just make sure your using the OE Charger or high quality charger that is designed for your phone/device.
Just because a charger it fits or has an "IC Chip" in it can mean squat due to low quality chips. The low quality chargers can damage your device and / or battery.
The proper charger will also stop charging when it is charged if its working correctly which is usually true with the OE Chargers.
Yes, they do heat up while charging especially if the battery is low, may get warm but should not get hot, you can check the battery temp with free APP or thermometer.
Its also good practice to top off the battery vs deep discharge cycles.
Hope that helps
•» Tip: Never rush to download any APP "Updates", read the feedback for a few days so that you can see if other people are having issues with it and/or changes to permissions or other you may not want! Always use a Back Up APP!
•» Free DropBox! Back up to & Sync your Phone to your Computer Free! Always have your stuff when you need it with @ Dropbox . 2GB Plus account is Free! Plus earn up to 500 Mb's for each referral! Up to 32GB Free! http://db.tt/szmjeyX
Reply
