1. MantisToboggan's Avatar
    My Active Applications Widget is incorrect. It now says 0 on the Widget, but clicking on it and opening the program shows "Active applications: 4" and it lists the 4 apps that I have recently used.
    Why is the Widget wrong? It worked when I first put it there.
    05-23-2012 06:17 PM
  2. sageleeone's Avatar
    me to?
    09-25-2012 06:39 PM
  3. Devinator's Avatar
    Is there an app associated with it? As in, can you go into Manage Apps and clear cache/data
    If not, is this a Widget specific to your device, or, did you download it? If it was downloaded, contact the developer and let them know. Even if you get a solution, they might want to know.
    09-26-2012 09:41 AM
  4. Leon Vilfand's Avatar
    Me too
    05-19-2014 08:48 AM
  5. srkmagnus's Avatar
    Check the refresh interval if one is available. Otherwise, remove then re-add the widget back to the home screen.
    05-19-2014 09:11 AM
