Results 1 to 2 of 2
    Default i need help
    I updated my drivers last nite to ne able to sync with my computer and now my texts won't go through...any advice?
  2. #2
    Default Re: i need help
    the forsaken reset would be last resort.
    or you could go into your messaging app and to force retrieve your messages and see if that works. If it doesnt, then do a soft reset. and then last resort would be a hard reset.
