Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By PvilleComp
    The Shag's Avatar
    Posts
    ROM
    CM7.2 on G2x
    Default Using a Tablet as an In Dash Device
    Hey guys, I plan on buying a car in a few months, and I have this grand dream of replacing the radio/nav stuff with a connected Android tablet, probably the Tab 7.0+ on TMo. I'd have Google Maps and all my music with Google's Car Home interface resting right in the dash.
    Of course, that's my dream. To anyone's knowledge, is that, like, a thing? Can that be done elegantly? Is that something I can have done at a shop or is there a kit to do it myself? Any help or personal experience would be much appreciated.
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Using a Tablet as an In Dash Device
    It's been done, but unless you are real handy with car dash stuff, I think a shop would do a real nice job. Plus they should be able to tie it into the eleteric system as well.
    Here are some links of others who have done it.
    Good luck!
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
  3. #3
    Default
    I've often believe that the in-dash stereo will become a thing of the past soon because we can get all of our entertainment needs from our devices now. Our grand kids will someday ask, what are car stereos? All you need is a unit that receives Bluetooth and has an amplifier driving the speakers. I have Sync in my Taurus & unlimited data (for now) so I rarely use the radio anymore. Use TuneIn for local shows and Pandora for other stuff. I have a profile setup that changes all my settings when the cars Bluetooth sees the phone. It's seamless & very cool. I use a modified Blackberry holster to hold the phone flat against my dash next to the radio and all looks really smooth.
    Sent using Droid Razr Maxx
    "When you turn your Android on, does it return the favor?"
    The Shag's Avatar
    Posts
    ROM
    CM7.2 on G2x
    Nifty! Thanks!
    The Shag's Avatar
    Posts
    ROM
    CM7.2 on G2x
    Quote Originally Posted by rbess1965 View Post
    I appreciate all of that, but I really don't like Bluetooth audio, or at least what I've heard. Is 3.0 any better?
  6. #6
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    The only problem I have with touch screens in cars is that you have to look at what you are doing to touch the correct button. Sometimes you have to watch for quite a while.
    With analog/mechanical buttons that are different shapes, I can adjust temp, change stations and volume without looking.
  7. #7
    Quote Originally Posted by PvilleComp View Post
    You have a point. That said, voice commands are getting better and better every day. I don't think it will it's too far fetched to imagine that luxury cars in the *very* near future will be able to be controlled completely via voice... That is, temp controls, internal lighting, perhaps even wiper blades and cruise control, will all be voice controlled. Put a button on the steering wheel that that activates the voice command and away you go...
  8. #8
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    I agree, but for voice to be solely used there will have to be a lot more work done on accent recognition! When a native Scotsman can hop into a Hertz rental and use voice commands without a "learning curve" then we'll have something!
    The Shag likes this.
    The Shag's Avatar
    Posts
    ROM
    CM7.2 on G2x
    Personally, I'm a very paranoid driver. Fiddling with it while driving is just not a thing I would do. When I've had rental cars and used my phone for Nav and music and an issue popped up, I would find a place to pull over and take care of it. A minor annoyance isn't worth getting killed over.
