Results 1 to 6 of 6
    Default LG Optimus V trouble shooting
    Im having trouble sending pictures from my phone.it keeps showing its sending but never sends.it shows that ring of timer if u know what i mean.i can recieve pics but cant sent them.never goes through or sends.i try reading the manual but nothing works.even settings i try playing with but nothing.does anyone hav or has had this problem?pm me please!!
  2. #2
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    ROM
    CLΞΛNЯOM
    Default Re: LG Optimus V trouble shooting
    Could be the size of the pic... if you're trying to send it by text message... try compressing/lowering the image size before sending. It also helps to have a strong signal/connection to the network when sending.. if possible, try turning on wifi.
  3. #3
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    @zonster--- in addition to cybers advice, have you tried going into settings>applications>manage applications>clear cache/data>reboot?...
    definately check out:
    [GUIDE] 2012 Optimus V Reference Guide (Start here!)
    and of course:
    [ROM+Kernel] Inferior Human Organs unofficial CM7.1
    Last edited by clodfelterac; 06-02-2012 at 01:27 PM. Reason: typo... my bad... :-)
    Thanked by:
  4. #4
    Default
    I'm a noob @ rooting my Optimus V vm670. I need sum help evry post, video & piece of info says I need 2 install gingerbreak apk v1.2. My issue is I DO NOT hv a CPU. I hv install frm unknown sources clicked & debugging according 2 instructions. Y wnt the 1st step download.
    Sent from my VM670 using Android Central Forums
  5. #5
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    Quote Originally Posted by gunna30 View Post
    you need a pc to obtain root with gingerbreak... i used it when i rooted mine... and i think it only roots zv5 baseband and below... if youre running a newer v then it may be zv9... but either way, as long as you can get access to a pc, we can help you... (by we i mean the completely awesome ov community here at ac)... do you know someone who has a pc that wouldnt mind letting you use it to root?... as long as you read up and get a good grasp of what you need to do then it doesnt really take that long...
    come to the ov forum... please, please, please, please, explore around and read, read, read... there is a great wealth of information here...
    http://forums.androidcentral.com/opt...ng-roms-hacks/
    read the sticky(s) at the top of the thread... it will save you a ton of stress!... :-)
  6. #6
    Naw u dnt need a computer to root the OV. Trust me, I know.
    You have to first download ES File Explorer from Play/MARKET. This will allow you to install apks from local storage.
    Then download Gingerbreak here: . If you can't download try using Opera Mini.
    Then just allow Unknown Sources, and open/install Gingerbreak with ES. Viola, rooted.
