Results 1 to 2 of 2
- 05-31-2012, 01:26 PM
Thread Author #1
- 05-31-2012, 02:30 PM #2
Re: Driod 2 and sync
Is Sync Bluetooth? Sometimes when you connect with devices VIA Bluetooth a pin must be confirmed. After selecting one device from the other to initiate a connection, a popup should display on both with the pin. It's been a while since I've had to do that, but, I think that's how it works.
Or, is there a Sync app that you have to download to connect?
HELP!!!
Reply
