Results 1 to 2 of 2
    Default Can An SD Card Cause Your Phone To Crash?
    So, I had this HTC Wildfire S that kept restarting and crashing. I then replaced the battery thinking that was the problem, but when that didn't work, I assumed it was the phones problem. Never did the SD card cross my mind, even though it had caused me issues before with unexpectedly removing itself.
    I went out and bought a new, better phone, thinking it was time for one anyway.
    So then now I have a brand new Motorola Triumph, and I transfer my same SD card to it. All is well and fine for many hours, and then the exact same problem I had with the Wildfire S begins AGAIN.
    My question is... could it really be the SD card doing all this? I took the SD card out of the Motorola and it seems to be better now..
    Sincerely,
    Sleep deprived and annoyed over phone troubles.
  2. #2
    pazzo02's Avatar
    Posts
    ROM
    Sabsa Prime ICS
    Default Re: Can An SD Card Cause Your Phone To Crash?
    Yes, it is possible, and from the sounds of it, probable. You can try reformatting your SD card. Make sure you do it in the phone. I've heard of people having problems when they format it on their computer. If that doesn't fix the problem, replace it.
