Just got HTC Evo 4G LTE, updating from tracfone (phone/text), but use Ipod touch(email/apps).
The big screen is really great. Main reason I got it was typing on ipod/iphone was not easy, and LOVING the voice dictation and swype.
I was as clueless about iOS 3 years ago, as I am about ICS today. But the settings in iOS make sense, I have no idea what most of the settings are in ICS. All the info online seems to be for previous versions, and ICS has no similarity to them. No + on main screen, Apps is totally different, so when I keep hitting a wall, I have no where to turn. Friends that have Androids say they just went with things as they came with the phone.
I dont like that you have to use 2 hands to turn on the screen. You can do it with one hand on ipod. Especially if you get distracted for a minute, with the iphone, you just use your thumb to turn the screen on. And the power button on the top of the Evo seems to be asking to get turned on in a pocket. Why is the on button on the left, not good for right handed people.
I am of moderate tech ability. I do not want to spend days getting my phone to work for simple things. While I understand that many love that Android has options, I would frankly like to have a good, simple phone that works easily and elegantly right out of the box. Other than the keyboard and voice recognition, almost everything I have tried to do has been frustrating and unsuccessful.
1 - Emails are too big for screen, even in landscape. If you cannot read the whole email without moving it back and forth each line, it?s a major hassle. You cannot pinch them to make them fit either, I tried different font sizes in settings, same result. This might be the deal killer, as if I cannot read emails quickly whats the point?
1a - No 2-line preview in landscape, so if you want to preview and read you are constantly rocking sideways, which is tedious.
1b - There seems to be only one way to delete emails. Android requires a 3 point touch to delete an email. IOS allows a left swoosh, touch to delete, very simple and quick, as well as the 3-point method.
1c - Is there a way to have the images always open in emails, instead of touching each one to open? Where is that Android flexibility?
1d - Saving as new, needs to hit drop down. On ipod just hit link. And you cannot see difference between new and saved as new on Android.
2 - I spent over an hour to get HTC sync on my computer then it says I need an SD card to sync - huh? Apple may be a PITA with update reminders but the sync works so easily.
3 - Not sure if there is a way to type in contact info from your computer. If you do not have it in Outlook or gmail contacts I assume you have to enter it directly into the phone-which is harder with a small keyboard.
4 - I have read on here how easy and wonderful Android is for putting icons/widgets in different places, but I seem to be limited to 4 on the main screen. I watched a video about widgets, but do not have a + button on my screen, so not sure how to access widgets. With ipod I was able to sync and move the icons around with a mouse on my computer.
I see screenshots of people having different configs, but clueless about how to do that, and have not found any help or guide.
5 - Is there a way to get a different tone for texts, emails and other notifications. It would be nice, like when I am at work, I would ignore tone for emails, as I am on my computer, but would look at texts.
It seems that if you use gmail and other google things, ICS is great, but its really not so easy for other email providers, etc For instance I dont see why they make a difference between getting a gmail email or another provider email, its all the same to me (and I do not get many gmails) Then every address gets a bing when it updates. On the ipod one ding is good enough for any or all accounts.
The first app I downloaded does not work with Andriod anymore it seems, (Currency), but will have to check out some other ones. (I see a bunch of people having trouble with Facebook like me)
While they say that with Android you have a lot of choices, so far I do not see them. Like its a big deal that you can have 4 icons on the first screen. The iphone/ipod has 16, but you do not have the lovely clock.
I got this big phone, as I do like the bigger keyboard for typing and like swype. But I have spent quite some time on trying to synch and it has not worked at all. The people in the store and when calling support are either not familiar with this new phone(as they have not seen it), or tell me that most of these things cannot be done. There are certainly issues with iOS, but it comes out of the box pretty usable. I am not finding the same thing for Android.
While it may be great for tech-savvy people can do all sorts of things, most of us want everything easy, accessible and elegant. Thanks for your help
New issues:
a-I get emails listing postings on yahoo groups. Normally you touch the post and it drops down to that post in the message. It does not do that on this phone. It say #1 cannot be connected, like its looking to go to the internet. Do not have this issue on ipod.
b-Downloaded a few apps, half do not seem to work. Just don?t open.
C - Downloaded doubletwist. Doesnt work as I have the wrong type of USB set up, whatever that means, never hear that before. Downloaded wondershare, and connect the usb cord, it just says initializing HTC Android device and never connects., tried to send email to them from the program-didnt go through. Frustrating!
New issues:
