1. eeyore6802's Avatar
    Ive been trying to find something as simple as itunes to sync my music and podcasts from there and am not having much luck(and im realizing notjing may make it as simple as syncing an ipod with itunes)
    The main thing i like syncing an ipod to itunes is how it knows for example what podcasts ive watched. then in itunes i can uncheck what ive watched, check what i havent and its synced.
    The programs ive been trying on the android just seem to list every single podcast that is there and i cant distinguish if theyve been watched or not. some also dont seem to allow me to pick certain podcasts, but i would need to select the entire folder of a specific podcast to sync.
    Id like to find something simple to be able to do this since my husband is anti apple, but im finding for my music and podcasts it would be simple to get an ipod again :-)
    Sent from my SPH-D710 using Android Central Forums
    06-04-2012 11:28 AM
  2. PvilleComp's Avatar
    Have you tried using iTunes with Doubletwist from the Play store?
    I don't use iTunes myself, but just about everyone I know who has used it loves it.
    06-04-2012 08:12 PM
  3. Ry's Avatar
    Music gets Google Music. Podcasts go to Google Listen.
    Sent from my DROID BIONIC using Android Central Forums
    06-04-2012 08:38 PM
  4. pazzo02's Avatar
    There's also iSyncr for syncing with iTunes. But to answer your question, no, I don't believe there is currently anything out there non-iTunes that is that intuitive. Not yet, anyway.
    06-05-2012 07:53 AM
