Results 1 to 2 of 2
    Default Gmail Messed up
    To begin with I'm sorry if this post is in the wrong area.
    I have a Boost mobile ZTE Warp, recently purchased about a month ago. Its set up and working just fine, however ever since I synced my gmail account onto it, my mail has been messed up. My mail has been going into the all mail folder and I'm not able to stop this from happening. Some mail will also go into the priority inbox or just the regular inbox. I had my account set up to sort into folders but now its all mixed together. It's gotten so bad I'm not even sure what mail has been read and what is getting lost into space. I'm lost on what is going on. Any help would be greatly appreciated. Thank you so much.
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Gmail Messed up
    Did you set it up in the Gmail app or in the Stock Mail app? You may need to delete it and then add it to the Gmail app.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
