Results 1 to 2 of 2
    D16RR's Avatar
    Posts
    Global Posts
    225 Global Posts
    Default Roaming: Can I pick the carrier?
    Is there a device or OS version that would, on ATT, permit me to select from a list of carriers and lock one of them while roaming, or to prevent roaming by locking to my home network?
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Roaming: Can I pick the carrier?
    Under settings -> Wireless & networks -> Mobile settings there should be options to allow or disallow roaming domestically and internationally.
    Hope this helps.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
    Thanked by:
    D16RR
