Results 1 to 5 of 5
    Default What to do before returning phone
    For those of you who have returned or sold an android device what did you do to make sure all of your personal information was removed from the phone?
    I never installed an SD card in my phone. Is a factory reset, all you did?
    Are there any other steps you could take to make sure data could not be recovered from your phone when it gets into another person's hands? Can someone still recover my data after a factory reset?
    Thanks, I appreciate it.
    I apologize if this topic was discussed in another thread. Feel free to lead me to a thread or answer and then delete this thread. I couldn't find a thread on it but it has to be in here somewhere. It is a really common occurrence.
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: What to do before returning phone
    If there is no SD card you might want to format your data partition on the device as well as a factory reset.
    Other than that you should be good to go.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
    Thanked by:
    DubM
    How would I do that? I am on an HTC EVO LTE.
    Is that just under "Erase phone storage" in the settings menu? Please help ASAP thanks!
  5. #5
    You say that never installed an SD Card on to your phone but depending on your phone there may be one that was installed by the carrier. Many of them would sell the phones with an 8GB card already installed. Check your phone model to make sure that you do not have one. If you do just remove the card.
    Before you wipe your phone make sure that you have made backups or synced the important data that you need so as to install it onto a new phone.
    Good luck.
    Doc
    EVO 4G
