Results 1 to 4 of 4
    Default Question regarding ESN
    Q1) I'm planning on breaking my contract with Sprint, paying the early termination fee, and then selling my Galaxy S2 to recoup some of the cost (love the phone, hate the network). That being said, Is it safe to assume that as long as I pay the early termination fee, the Galaxy S2 will have a "clean" ESN and someone else could use it on Sprint?
    Q2) If the above works as planned, I will purchase the Galaxy S3 on Verizon when it becomes available. Using Titanium Backup, would I be able to move apps and contacts to the new phone?
    Any help is appreciated.
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Question regarding ESN
    Yes, if you pay the ETF the ESN should be good.
    On your other question - I would move your contacts to Gmail rather than use the phone contacts, then they will automatically sync when you sign in to the new device with your gmail account. Apps are another story - I would download fresh apps from the market and let them install natively. For the few apps that maintain state, like Games, I would just restore the data for those apps. If it works great, if not... Oh well.
    Remember you need root on the device to run titanium for the restore.
    Hope this helps.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
    Thanked by:
    Thanks for the response, it was helpful. One last question. If I download previously purchased apps on the new device, will the Market realize I've already paid for them?
  4. #4
    supermanx5's Avatar
    Posts
    Global Posts
    9 Global Posts
    Yes, so long as you use the same Gmail account with the Play Store it will recognize all the apps you've purchased. And as far as the ESN thing goes, your good as long as you pay the ETF. I used to work at Sprint
