Hi,
I think I may have just bricked my phone after one day. Can anyone help let me know if I should toss this thing in the garbage or if there is another way to get it to boot that I am not finding.
Some background info... I rooted the Samsung Infuse that I just had bought used and I was trying to follow these instructions (http://forums.androidcentral.com/t-samsung-infuse/115831-rom-manager-backup-stock-rom.html) to get Clockworkmod to backup my old rom because it would not work by default:
Unzip it
copy unzipped file contents. Should be just "Recovery"
Browse to /system/bin/
Enable read write access if need be
find "Recovery" and rename it (Recovery.bak)
paste downloaded Recovery file
Reboot
Install update.zip from recovery (might have to try 3 times)
I got to the final step and in a moment of stupidity (I'm thinking it must have been now) I clicked the Install button from Rom Manager and chose the Update.zip file. My phone then went to reboot and got stuck on the Samsung screen. I swear I have tried every combination of the power, volume and home buttons being held down to get into recovery mode but have not been able to. I guess looking back I should have used a lot more caution but it just seemed from everything I read that everyone could always get into the recovery screen if nothing else. I guess I have got to use to messing around on Linux where I can always use a live CD and chroot in if I do something stupid.
Let me know if there is any more information I can provide that would help someone understand my problem. I am comfortable with command line if there is any way to get it off this screen. I am just under the assumption that I am screwed because it won't go into recovery mode now. Sucks because now my girlfriend will never let me root again since she was already saying I was stupid this time.
Any suggestions are welcome. It will becoming a coaster otherwise and I will be stuck going back to my iPhone 3gs.
Unzip it
Reboot
