Results 1 to 4 of 4
    Default Window limit reached
    How do I close windows on the browser?
  2. #2
    Default Re: Window limit reached
    What browser? Device? OS version?
  3. #3
    kcerica's Avatar
    Posts
    Global Posts
    72 Global Posts
    Default
    If you are still wondering how to remove windows, in the stock browser all you have to do is push the menu key to open the options then click windows and push the x next to the windows you want to close. I'm sure it's pretty much the same in all browsers.
    sent from my Reborn optimus s using taptalk
  4. #4
    how do it close window?
