Results 1 to 3 of 3
    Unhappy bricked straight talk lg optimus q
    umm hi, i kinda screwed up my straight talk lg optimus q, i was messing around with a root uninstalled & uninstalled the android systems (i guess the root of the phone) & now it wont boot past the lg screen, i can get to the recovery menu but i can't find the "GOTA update file" (thats what it appears to be looking for) if any one can point me in the proper direction of the file or any file that can be placed on the sd card to restore the android system i'd be eternally grateful
  2. #2
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    Default Re: bricked straight talk lg optimus q
    you can download it from:
  3. #3
    this doesnt want to recognize my phone as updatable. and i cant seem to be able to access the sd card via usb. same problem bricked after i rooted it. it was fine for about 12 hrs then it just got slow and now the touchscreen doesnt work but i can use the keyboard and occasionally get a touch in there to get past my swipe security
