Results 1 to 2 of 2
- 06-14-2012, 09:40 AM
Thread Author #1
Widget Help
Hi! I have the htc thunderbolt. I downloaded the battery widget from geekyouup and the version is 1.6.11. The application shows up in my application manager but does not show up in the application tray so that I can put it on my home screen. I tried moving to SD card but can't. It looks like its not even running however it is downloaded. When I access it through application manager the only option that it gives me is to uninstall. Any help would be much appreciative. Thanks!
- 06-16-2012, 10:22 PM #2
Re: Widget Help
It's a Widget not an app, you load it by long pressing on the home screen and selecting Widgets. It may be under personalize on the T-Bolt.
Hope this helps.Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
Reply
