DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Results 1 to 2 of 2
    Question 4g ---> 3g
    I just got the galaxy s3, it runs 4g on tmobile.
    I was wondering if i could make it run 3g.
    I can only seem to get it to run 4g or NO internet at all.
    Any tips would be helpful! thanks
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: 4g ---> 3g
    T-mo 4g is HSPA+ (3G on Steroids). It's not LTE so it should not have any adverse battery drain. I'm assuming that you want to turn off 4g to save battery.
    Hope this helps.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
