Sync bookmarks between desktop IE and Android?
Malathan
Active member
Jun 14, 2012
33
Currently have a droid x phone (upgrading to Samsung GSIII shortly), but have never figured out how to dynamically sync bookmarks between it and my desktop. On the flip side, I have an ipad and through icloud, bookmarks are dynamically synched between the two - add bookmark in IE on PC and it appears on ipad, as well as the other way around.
I have found posts where people say on export/import, but that is a one time shot. Looking for something that is automated. Any ideas?
If you switch to the chrome browser on your desktop and your galaxy s3 the bookmarks will automatically sync between the two. To my knowledge there is no way to dynamically sync using IE.
Sent from my Droid Incredible running CM7
Lelix2603
