HTC Sensation - how do i delete the dock mode!
magicmarc
22
when i goto manage applications, i select the dock mode, and its offers to clear the cache, etc... but there is no option to delete it or uninstall it, or disable it.
my phone constantly goes into the docking screen, constantly, i dont want the mode at all.
thanks
m
If you are not rooted you will not be able to remove the Dock mode. It's baked into the ROM and you don't have permissions to remove it like an app downloaded from the Play store.
Check in the settings and see if there are dock settings you can disable.
Instead of deleting it you can disable the whole app. This means that the app won't start if you don't enable it again.
Skickat fr?n min Galaxy Nexus via Tapatalk 2
Techview
