1. jamiefinney's Avatar
    is there an app on the market place that tells you about upcoming / in progress sales and reductions in the store?
    07-02-2012 08:20 AM
  2. srkmagnus's Avatar
    There's no specific app that does this that I'm aware of. If there are any deals to be had Android Central will definitely cover it. If there's an app you are waiting for follow the developers twitter or blog and check it frequently. If there's a price drop they will likely post at one of those two resources.
    07-02-2012 10:05 AM
  3. jamiefinney's Avatar
    thanks for the reply i'll keep an eye out
    07-03-2012 04:09 AM
  4. Caped Codder's Avatar
    I like AppSales. It uses notifications.
    Sent from my DROID4 using Tapatalk 2
    07-03-2012 04:40 AM
  5. jamiefinney's Avatar
    i just found that and was about to add a link to the post. is it pretty good? can't try it yet as my first android is the nexus 7 which isn't out for a couple of weeks.
    https://play.google.com/store/apps/d...appsales&hl=en
    07-05-2012 05:23 AM
  6. Caped Codder's Avatar
    It works very well. It will show a notification when it finds new sales. When you touch the notification it will show sale items for the past few days. You can ask to see older items and it marks them "expired" when the sale is over. I've used it to purchase several apps including Tapatalk that I'm using now. Seems like a few times a day it will find new items.
    07-05-2012 06:38 AM
