Hi all! I've read through everything I can find on rooting an Android device. I've installed the SDK, added the ADB.exe folder to the path, downloaded SuperOneClick.exe, backed up my phone and unmounted the SD card.
When I click on Root in SOC, I get the following (my read of the error messages looks like the commands failed BECAUSE I'm not rooted--so how can I root if the commands to root won't work if I'm not already rooted?):
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
$ export TEMPRANDOM=21915;export PS1=END:$TEMPRANDOM;getprop ro.build.version.release
2.3.4
END:21915export PS1=""
export TEMPRANDOM=45388;export PS1=END:$TEMPRANDOM;getprop ro.product.manufacturer
motorola
END:45388export PS1=""
export TEMPRANDOM=42771;export PS1=END:$TEMPRANDOM;getprop ro.product.model
DROID Pro
END:42771export PS1=""
export TEMPRANDOM=91210;export PS1=END:$TEMPRANDOM;getprop ro.build.version.incremental
120113
END:91210export PS1=""
export TEMPRANDOM=81941;export PS1=END:$TEMPRANDOM;ls -l /system/xbin/su
/system/xbin/su: No such file or directory
END:81941export PS1=""
export TEMPRANDOM=60562;export PS1=END:$TEMPRANDOM;ls -l /system/bin/su
/system/bin/su: No such file or directory
END:60562export PS1=""
export TEMPRANDOM=21915;export PS1=END:$TEMPRANDOM;chmod 755 /data/local/tmp/busybox
export TEMPRANDOM=61084;export PS1=END:$TEMPRANDOM;rm /data/local/tmp/boomsh
END:61084export PS1=""
export TEMPRANDOM=98833;export PS1=END:$TEMPRANDOM;rm /data/local/tmp/sh
END:98833export PS1=""
export TEMPRANDOM=30140;export PS1=END:$TEMPRANDOM;chmod 700 /data/local/tmp/zergRush
END:30140export PS1=""
export TEMPRANDOM=84035;export PS1=END:$TEMPRANDOM;cd /data/local/tmp/
END:84035export PS1=""
export TEMPRANDOM=70730;export PS1=END:$TEMPRANDOM;./zergRush
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary. All rights reserved.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00015118
[*] Scooting ...
[*] Sending 149 zerglings ...
[*] Sending 189 zerglings ...
[-] Hellions with BLUE flames !
END:70730export PS1=""
export TEMPRANDOM=31488;export PS1=END:$TEMPRANDOM;/data/local/tmp/busybox mount -o rw,remount /system
mount: permission denied (are you root?)
END:31488export PS1=""
export TEMPRANDOM=96072;export PS1=END:$TEMPRANDOM;/data/local/tmp/busybox mount
rootfs on / type rootfs (ro,relatime)
tmpfs on /dev type tmpfs (rw,relatime,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
none on /acct type cgroup (rw,relatime,cpuacct)
tmpfs on /mnt/asec type tmpfs (rw,relatime,mode=755,gid=1000)
tmpfs on /mnt/obb type tmpfs (rw,relatime,mode=755,gid=1000)
none on /dev/cpuctl type cgroup (rw,relatime,cpu)
/dev/block/mmcblk1p21 on /system type ext3 (ro,noatime,nodiratime,barrier=1,data=ordered)
/dev/block/userdata on /data type ext3 (rw,nosuid,nodev,noatime,nodiratime,errors=continue,barrier=1,data=ordered)
/dev/block/cache on /cache type ext3 (rw,nosuid,nodev,noatime,nodiratime,errors=continue,barrier=1,data=ordered)
tmpfs on /data/tmp type tmpfs (rw,relatime,size=2048k)
/dev/block/pds on /pds type ext3 (rw,nosuid,nodev,noatime,nodiratime,errors=continue,barrier=1,data=ordered)
/dev/block/preinstall on /preinstall type ext3 (rw,nosuid,nodev,noatime,nodiratime,barrier=1,data=ordered)
END:96072export PS1=""
export TEMPRANDOM=32379;export PS1=END:$TEMPRANDOM;/data/local/tmp/busybox mount -o rw,remount /dev/block/mmcblk1p21 /system
END:32379export PS1=""
export TEMPRANDOM=80818;export PS1=END:$TEMPRANDOM;/data/local/tmp/busybox mount
END:80818export PS1=""
export TEMPRANDOM=63476;export PS1=END:$TEMPRANDOM;mount -o rw,remount /dev/block/mmcblk1p21 /system
mount: Operation not permitted
END:63476export PS1=""
