I have a Samsung Galaxy SII, and am curious, the video quality isn't bad on normal, but the more you zoom in, the blurrier it gets. Is this normal or is there some kind of "fix" for it?
Evil Monkey is correct - Digital zoom is Faux Zoom, it's just zooming in on the original image and you lose resolution depending on the quality of the original image.
