Results 1 to 2 of 2
- 07-07-2012, 03:59 PM
Thread Author #1
Do MACs work well with Rooting Android Phones?
I currently have a PC, Vista and I am looking to switch to a MAC possibly. My dilemma is I root all my phones and tablets, which would steer me away from a MAC if they weren't compatible.
Does anyone use a MAC full time to root? Is it very different than a PC? & Would you recommend it even over a PC if you use a MAC? Just looking for some opinions. Thanks guys! - 07-07-2012, 09:44 PM #2
Re: Do MACs work well with Rooting Android Phones?
I'm on a Mac and have rooted HTC and Samsung devices. In most cases there is a manual method with line commands to root and you'll just have to convert some commands. If all else fails run Linux or Windows through a Virtual Machine.
Reply
