Hi, I am new to this forum and new to android tablets, and so far I am having very little fun at all, my Ainol Elf II has many problems and hours of trawling through forums has not so far helped at all!
Problem 1- WIFI
My Elf will find WIFI networks no problem at all, I clicked on my home network and entered password... then nothing happened, I clicked again and pressed connect, nothing happened! I kept trying this and eventually it said obtaining IP etc and then "connected" great! But my celebration was short lived, as my network status was shown in grey and browser told me i was not connected to the internet. I have also tried at my sisters house and it does not work there either, dispite my sisters blackberry tablet and my samsung galaxy 550 phone working on both networks. The elf does however work fine at my girlfriends house, she has no password for her network, so is it possible my tablet is struggling with secured networks, if so, any advice on how to fix it?
Problem 2- External SD
I have bought a 32gb external micro SD card for my elf, because its primary purpose to me is to edit and store photographs i take while i am travelling. I cannot do that because the card is not showing up in the Elf's FileBrowser. Card works fin in my Galaxy, and if i connect the Elf to my computer via USB the SD shows up there too. The only thing in my FileBrowser device list is "SD Card" which is actually the internal storage. Weirdly my Elf is recognising the external SD in Recovery Mode! Any ideas how to solve this?
Problem 3- ROOT
In the hope it would solve the above problems I've attempted to install the Feiyu ROM but I cannot because I cannot ROOT it, I've put the root.zip file onto my external SD booted my Elf in recovery mode (- + power), apply update from SD, and selected the root.zip I just get the error message:
E: signature verification failed
Installation aborted.
I read somone had the same problem on a forum and the suggested fix was to use Novotools, or Clockworkmod ive tried both... non of the buttons respond in Novotools, and Clockworkmod tells me i need to Root my device before using it.... Grumble Grumble... again any help would be greatly appreciated!
Problem 4-
in 48 hours I am flying to Australia for 6 months where i will need my tablet for photo editing and storage, and internet use!
I am not being lazy I have spent many many hours googling to solve these problems but all has failed, if anyone can help i would greatly appreciate it!
Problem 1- WIFI
Problem 3- ROOT
Problem 4-
