1. cjb44's Avatar
    My Galaxy S3 (AT&T) came with 7 home screens that I can move between (new to android from Blackberry. Maybe each isn't called a home screen)...is there a way I can delete some of those screens because most of them came with apps I don't want to use so once deleted I have blank pages. No reason for that.
    Thanks in advance.
    07-16-2012 10:09 AM
  2. Rocky2's Avatar
    To delete the home screens do the following:
    -Grab the screen with two fingers in opposite corners
    -Pinch to the center
    -All home screens should be visible on one screen now
    -long press a screen you don't want, and drag it down to the trash can at the bottom
    -If you want to add screens back, press the + symbol
  3. Devinator's Avatar
    Not sure exactly how this would be done on an S III. On my Prime, if I hit Home twice it brings up all my screens, and, I can drag them to the trash like you would to uninstall an app, or, remove an icon.
    However, I am using a custom launcher. I am using Nova on my Prime and Holo on my X2 (until I get around to something else). I was able to do this in both. I would think you could do it right out of the box though. Are you running a launcher or no?
    07-16-2012 11:20 AM
  4. veronica rante's Avatar
    I have orange monte carlo,I delated some apps installed but suddenly nothing appear in the screen,what is the problem about my phone?
    07-16-2012 01:43 PM
  5. Rocky2#AC's Avatar
    howserow likes this.
    07-16-2012 01:51 PM
  6. howserow's Avatar
    Thanks for the tip....I could not figure it out!
    12-24-2012 03:20 PM
  7. Tom Willson's Avatar
    Nice tip, thanks. Worked like a charm. ;>)
    07-13-2013 03:40 PM
