Results 1 to 10 of 10
    sohan's Avatar
    Posts
    Global Posts
    5 Global Posts
    Question Apps not working while roaming?
    I use Tmobile UK and I got to Amsterdam last night. My whatsapp stopped working and today I rebooted the phone and now all my apps except Chrome and Gmail do not work.
    I having a roaming plan with TMobile so I'm not sure why my apps have stopped working. Do I need to enable certain stuff to keep them working?
    I recently switched from BB to Samsung Galaxy S3 so I'm still new to Android.
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Apps not working while roaming?
    Have you tried uninstalling Whatsapp, rebooting, and then see if the problem is fixed?
    sohan's Avatar
    Posts
    Global Posts
    5 Global Posts
    Yep, hasn't been any help. Hasn't randomly started working again either.
  4. #4
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    Hmmmm.... Are you rooted?
    sohan's Avatar
    Posts
    Global Posts
    5 Global Posts
    Nope, thought about it but didn't end up rooting. It's a S3 from Tmob UK stock.
  6. #6
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    I'm sorry, I have no idea what to tell you. Can you elaborate on how they Don't work? Do they force close, do they not launch at all, do they open but just not function?
    sohan's Avatar
    Posts
    Global Posts
    5 Global Posts
    They open, just not function - whatsapp messages just don't deliver until I connect to wifi but chrome and gmail work fine :S
  8. #8
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Quote Originally Posted by sohantanna View Post
    So, you uninstalled it, rebooted it, didn't reinstall it, and, those are the only two apps that work? From the way your last post was worded, it sounds like Whatsapp is still installed.
    Otherwise, factory reset maybe?
  9. #9
    Default
    Mine does that when I have bad signal, try turning it to airplane mode so it won't search for updates...could be it
    Sent from an Optimis Elite powered by Android via Virgin Mobile
  10. #10
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Sounds like more of a network problem than a phone problem. Have you tried calling Tmobile Amsterdam tech support?
