Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    varockchick's Avatar
    Posts
    ROM
    quattrimus-VM670-cm9
    Default Re: Everything SD Cards - Discussion and How to
    Quote Originally Posted by kobequintana View Post
    787/480 savagedzen is recommended!
    This Song Rocks:
    Forever Given Forever You
    By: Evanescence
    thanks....the 480/600 is slow....delay in typing text in sms...now if i could only get the voice search mic to show up on the keyboard in an sms id be happier than a possum eating sh*t...lol...it works in google search ....I can even hit it and say send text to whoever and say what i want and it will send it....dont really wanna download some third party kb but might have to
  2. #27
    kobequintana
    kobequintana's Avatar
    Guest
    Default
    Quote Originally Posted by varockchick View Post
    Yeah that cpu setting wrks great with the CM9
    This Song Rocks:
    By: Evanescence
  3. Thread Author  Thread Author    #28
    strabo231's Avatar
    Posts
    ROM
    Quattrimus CM9
    Are you opposed to Swype? If you get Swype beta you'll have the search mic
  4. #29
    Posts
    ROM
    Quote Originally Posted by strabo231 View Post
    Ive never tried swipe...might give that a try....something new to play with....YAY.....lol..
  5. Thread Author  Thread Author    #30
    strabo231's Avatar
    Posts
    ROM
    Quattrimus CM9
    Ive never tried swipe...might give that a try....something new to play with....YAY.....lol....just looked in the market and dont see swypw....slide it and other kb....
    Edited that last post a sec ago. Link there. Wont find it in android market.
    Thanked by:
  6. #31
    XRAY72's Avatar
    Posts
    ROM
    cm7.2 rc1/2.6.35.7-perf.
    i made a few different copies to my pc. partitioned the card in the phone,but still lost some apps. it takes forever to try re-downloading an app from the store (been over 15 minutes and counting for one of them). where did they go, and how do i get them back?titanium backup doesnt even acknowledge the backup that i did before i startrd this mess. when i check storage, it shows internal still at the same level. a bunch of my apps are grayed out in the apps part of settings, i click them and try to move them to phone, and it says app doesnt exist. how do i even see this partition? im so frustrated i almost wish i'd never tried partitioning my card. i have the backups still on my pc,should i try again?
  7. #32
    I honestly didn't understand any of that, so I really don't know if it is helpful, but just in case it is maybe someone can translate for me, haha.
    My phone is running low on internal memory and I have an SD card but not everything will move to it. Is there some way I can move the apps that come with the phone onto the SD card? (Like messaging, browser, YouTube, contacts, etc.) And maybe any "unmovable" apps, too? Like, is there some sort of external thing I can get/do to help? Any help would be greatly appreciated, thanks!
  8. #33
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Quote Originally Posted by Shoshananana View Post
    App2SD from Google Play (it's free). If you want still more space it depends on your phone. Some custom ROMS will use a partition on the SD card as "internal" memory, so you can have a few GB of "internal" memory. But there has to be such a custom ROM for your phone. You can't move a lot of the system apps (like contacts, etc.) to the SD card, but you can install everything you download to it. (I have all kinds of junk on my phone, and still have well over 1GB of "internal" space left.)
  9. #34
    Well, I got App 2 SD, but it only moves the stuff I could move myself. Do you possibly know of any other ways I could save room on my phone?
  10. #35
    hey, i have been having this issue with my ext sd card provided in the box when i bought my note 2.
    i rooted my phone and all and ws using app2sd to swap my apps but it says tht my ext sd card is emulated and it isnt real physical space :S
    what should i do?
