Verizon Won't Upgrade Me !!!
Aug 15, 2010
13
dollardrip.com
So, Verizon doesn't let you extend your contract and upgrade your phone anymore. I'm currently stuck with the Droid X 2 and I'm not due for an upgrade until next year.
Does anyone have any tips on how I can make this happen anyway? I tried to talk to customer service and they tried to get me to add a line. This proved to be nonsensical because after cancelling the line it would cost the same amount in the end as it would to pay full price.
So how can I get a new, upgraded phone at a discounted price? If not through Verizon, where should I go? I want new, I'm not too big on used.
Side note: what would you say is the best Verizon Android phone at the moment?
Thanks in advance!
MrSmith317
Mr Fix-It
Mar 1, 2010
2,206
277
When did you buy your X2? If it was only a year ago then you're stuck.
Best Android phone on Verizon is subjective. Probably the SGS3 or Gnex though if you go spec for spec
Technified
478
4
You can try eBay or Craigslist. Other than that you gonna have to go the full retail price route.
Sent from my SCH-I535 using Android Central Forums
JOHN39
Active member
Jan 7, 2012
32
I have the same issue. If you're on a family plan you can transfer someone else's upgrade to you, but then you can only use that to get a phone from Verizon not from Amazon, and then pay a $30 upgrade charge.
tallsc
4
You can add a line, just put a regular phone on it and block the data but you have to pay $9.99 more a month on your bill for the line
knowledge is power
