Results 1 to 4 of 4
    PSUGradAtl's Avatar
    Posts
    Global Posts
    57 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to Access micro SD Card
    I installed a 32 GB micro SD card into my Samsung Galaxy SII. My device appears to recognize it in Settings | Storage since it shows Total space for the SD card as "29.71GB". However, I cannot figure how to browse to the card nor how to move files to it from within the Android OS. From within the My Files app, I cannot change directories from what appears to be the built-in memory since the "Up" icon is grayed out.
    How do I access the microSD card by browsing to it and moving files to it?
  2. #2
    strabo231's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quattrimus CM9
    Default Re: How to Access micro SD Card
    Get on the play store and get ES File Explorer. Great file manager
    PSUGradAtl's Avatar
    Posts
    Global Posts
    57 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, it appears there is a folder entitled "external_sd" that is some sort of mount to the micro sd card. I didn't see this before even though I had browsed through the list with the My Files app numerous times. I'm not sure how the user is supposed to just *know* that this is how the card is accessed...
    So I don't need another app afterall. However, ES File Explorer seems a pretty nice full featured app. I'll have to play around with it.
  4. #4
    nova9sw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    [SIZE=5]How do I download to and use apps from my SD card my LG Optimus L9 phone?[/SIZE]
