Results 1 to 3 of 3
    Default Droid Razr Maxx not charging
    I usually charge my phone over night and I have never had any problems. Last night my phone didn't charge and I woke up to a 15% charge. I figured that I must have knocked the charger out of the outlet, so I just took it to work with me to let it charge today. It's been charging for almost an hour and there is still no change in the charge (now it's at 10%). When I go under settings and look at battery use, I see that I have "1d 0h 18m 22s on battery." I don't know if my phone is just incorrectly reading my battery or something. Has anyone else had this problem? Is there a way to fix it?
  2. #2
    Default Re: Droid Razr Maxx not charging
    I'm having a similar issue. I spent the night at a friend's house and went to bed with 60% charge, woke up and it was almost dead so I went home and put it on the charger, it's been on two different chargers and tried 4 different outlets and the phone doesn't charge at any of them. When I try to turn it on while it's on the charger it just shows a screen saying 0% battery life and never charges.
  3. #3
    Quote Originally Posted by spacetime89 View Post
    Just spent more time looking into the issue. Not sure what causes it but I found something that works. Press the Screen Lock button (Top Right Physical Button) and the Down Volume button just below it together for 10-12 seconds. After I did that it did a reboot and was able to charge again.
    Hope this helps.
