Results 1 to 1 of 1
- 07-29-2012, 12:54 PM
Thread Author #1
MS OneNote File Location in Android - HELP!
My problem is, I deleted (screwed up) a OneNote Notebook on Skydrive. Can't find it anywhere on my laptop. But, I have turned off the sync on my version located on the Transformer Prime. I can read the files on my Prime! But, how can I protect, copy, save the files to another location in my tablet? I can't find them using the explorer. I don't want to turn on my WiFi until I get this done.
I'm hoping to be able to get the copy to my pc or just upload it back to skydrive... I'm afraid that if I just let it sync, the transformer will see the deleted action on Skydrive and just delete the notebook from the tablet.
Please help!
John
Reply
