StayFly Well-known member Apr 24, 2010 562 2 0 Visit site Jun 27, 2010 #1 I'm coming from the blackberry and i use to build my own themes is there a theme builder for the android?
D Dallin Hampton Active member May 26, 2010 30 0 0 Visit site Jun 27, 2010 #2 Panda home is a packaging and publishing utility. You have to make the graphics on your own (unless you pick from some of the ones supplied) so knowledge in photoshop will be a plus for you. go to http :// code . google . com / p / pandahome
