Results 1 to 14 of 14
    Default Battery fast discharge, fast charge
    For several weeks, my battery life has been unusually poor, and more recently, I've experienced sudden drops, like from 30% to 0% in a matter of minutes. Or one minute the phone is at 19%, then it's dead.
    [Screenshots below]
    Also, I'm finding that the phone charges very fast.
    This is the original battery on a Samsung Galaxy S II Epic 4G Touch, purchased Oct. 2011.
    I have a lot of news apps (Flipboard, Current, Pulse, Facebook, several newspapers), but their polling wouldn't explain sudden drops and fast charging. The phone often is very hot, which I always assumed was due to poor Sprint signal in the area. This evening, the phone remained hot even after I put it in airplane mode.
    Do I need a new battery or a new phone?
  2. #2
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Default Re: Battery fast discharge, fast charge
    Judging by your signal...you have very poor reception for both wifi and carrier. From what you mentioned it looks like a combination of a bad signal combined with background processes/data running in the background. Social networking apps, weather apps, basically anything that's set to constantly update will kill your battery quickly with that poor of a signal.. it will also cause the phone/battery to become hot because its working harder overloading the system.
    Also for the future, I noticed you were having trouble uploading pics, please do not host them on personal websites, either use an image hosting site or use the built in file attachment option using this site as a host.
    Thank you
    CW, thanks for the quick and helpful response.
    For the period covered by the screen shots above, I wasn't near any WiFi. Plus, I was in an area known for very poor Sprint coverage. What looks like a break in WiFi is the period when I had the phone in airplane mode.
    I've experienced this erratic battery behavior in a number of situations lately. The image attached here shows another period Thursday and Thursday night.
    Doesn't the very rapid charge seem unusual?
    Sorry about the issue with posting images. Thanks for fixing it for me, and I hope I have it righ this time.
  4. #4
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Rapid charging is unusual.. unless you're running a custom ROM/kernel that has that built in.
    I'm looking at your notification bar.. I'm not familiar with that phone so maybe someone can help you out better but it looks like you have wifi turned on and airplane mode which is strange. Is that your wifi icon I'm seeing with the one dot?
  5. #5
    Default
    How can you tell the signal is poor. Do the colors represent signal strength?
    Sent from my SCH-I535 using Android Central Forums
    No custom ROM, no rooting.
    At night I put the phone in airplane mode to avoid phone calls when I'm sleeping; but I keep WiFi on so I get emails overnight.
    Also, as I get very poor signal in my basement, I will sometimes turn the phone off, route my calls to a landline or Gchat (via Google Voice), but keep the WiFi on.
    Delldude, the colors do mean something, but there doesn't seem to be total consensus on what color means what.
    2.3 gingerbread - What's the meaning of signal strength colors in battery usage screens? - Android Enthusiasts
  8. #8
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    I'm not even going by color.. your screenshots all show that you have 1 or less bars out of 4 for wifi according to the icon in the notification bar which is bad.
    I called Sprint tech support. Of course they can't test a battery over the phone. They speculated either the battery was defective, or maybe there is a short in the phone.
    I took the phone to my local Sprint store. They didn't really look at the phone at all. Told me my battery was swollen due to overcharging. I shouldn't be charging the phone overnight, they explained, as it results in overcharging. (Don't most smartphone users leave the phone on the charger whenever possible.)
    Is a swollen battery my fault, or is it defective?
  10. #10
    its definitely the phone signal.. I have had similar issue when i upgraded from ginger bread to ICS... i did a force update using recovery and it messed up the antenna.. the phone signal was in brown orange on battery stat... then i did factory restore and it was back to normal.
  11. #11
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Quote Originally Posted by jlehrer100 View Post
    Next time find someone who actually knows what he's talking about.
    1) The charging circuit in the phone will shut off when the battery is fully charged, then kick in to top the battery off as the charge drains down.
    2) Overcharging a LiIon battery doesn't result in swelling, it results in heat - which usually results in a fire or explosion. (Remember the defective batteries a few years back?)
    A swollen LiIon battery usually indicates an internal short in the battery. The sudden discharges seem to indicate that one cell has developed a dendrite - a little mineral shard that grows during discharge. That pierces the separator, shorting the cell, resulting in rapid discharge.
    Is it a defective battery or misuse on your part? Hard to say. Most battery manufacturers will replace the battery without trying to determine what caused the dendrite (because modern batteries shouldn't develop dendrites), but whether Sprint will or not is another matter. You'll probably need the battery replaced, one way or the other. Then, with the new battery, fully charge it before using it the first time (keep the phone off). Then wait until it tells you to charge it, or turns off, before charging it again. Go through this cycle (full charge/full discharge) 3 times. From then on you can charge and discharge it however you like.
    Nonsense. At worst, the charging circuit failed to stop charging the battery (still their fault if they sold you the phone).
    Probably not. But overnight? Probably. (I've left LiIon batteries on charge for months at a time. And I still expect - and get - at least 3 years from a battery. In fact, the original battery in my V-550 phone - about 8 years old - is still working fine. [The phone is pretty useless, but the battery is good.])
  12. #12
    I also have the same stupid problem. My battery drain pretty fast and it is the android os which uses the most power. I got several new batteries and all seems to be having the same problem. It charges really fast and drain fairly quickly. I rooted the phone due to this problem and deleted unwanted Google apps. there is a little bit of improvement, however the battery drains fast, in 12 hrs it all gone.
  13. #13
    Default Re: battery charges quickly and drains fast
    I have a problem with my HP slate 6. It charges very fast and drains quickly. How could I get rid of this problem?
  14. #14
    Quote Originally Posted by lablanka71 View Post
    The operating system will almost always take the most battery, followed by the screen. You might want to check what rooting software you use, some have viruses. On another note, it could just be your phone's software. Something like the galaxy S4's battery problem.
