1. markw10's Avatar
    The Nexus 7 seems like the perfect tablet and I plan to purchase the 16GB version shortly. I also have the Xoom and have used the memory card slot for extra memory.
    With the smaller size of the Nexus 7 I plan to use it frequently while on the go. I know that the Nexus 7 unfortunately doesn't have a memory card slot. This is unfortunate but with the Micro-USB port are there any options for additional storage? I know there's devices that can plug into this but that it depends on what Android Jelly Bean can support. I'd like to be able to simply purchase a memory card reader that can plug into it and have memory cards inserted into it. I'd even use the option to have an external hard drive if necessary. The only thing I've come across is the possibility of using wireless hard drives for storage.
    Has anyone been able to add external storage such as the solution with a memory card reader and a memory card? If not, what hard drive solutions, wireless or not, work?
    Thank you for your help with the above questions.
    08-07-2012 05:25 AM
  2. still1's Avatar
    Check this out. you need root
    How to Use a USB Drive with the Nexus 7
    08-07-2012 09:53 AM
