newbie questions - Google Nexus GSM
anon(1039967)
5
I apologize upfront if this is a duplicate post.
I have followed these directions: http://forums.androidcentral.com/google-galaxy-nexus/136580-how-oem-unlock-galaxy-nexus.html
I have converted from yakjuux to yakju
Google has updated my phone to Jelly Bean
Do I/Should I wipe my phone and install only Jelly Bean, like I would to my iPhone when there is a major update?
If so how would I root/wipe my phone so that I have no OS and install only Jelly Bean?
Thank you
Its not a must that you have to wipe the phone before you apply a update from google(previous version to new version).. but starting fresh is always good and will have less issues.. since you wipe clean the phone it always good to install from scratch
If you want to fresh install from scratch go here and dnload factory image for yakju https://developers.google.com/android/nexus/images
extract the file and place all(bootloader-maguro-primelc03,image-yakju-jro03c,radio-maguro-i9250xxlf1) files in "C:\Program Files (x86)\Android\android-sdk\tools\" from your link above. or wherever you installed sdk.
open command prompt like when you ran "fastboot oem unlock" I think step 4 and 5 in your link.
now here is the instruction from flash-all.sh file in the extracted factory image.
if you open flash-all.sh(file in the factory image you downloaded from my link) with word doc you should see this below. I removed "sleep 5"
fastboot flash bootloader bootloader-maguro-primelc03.img
fastboot reboot-bootloader
fastboot flash radio radio-maguro-i9250xxlf1.img
fastboot -w update image-yakju-jro03c.zip
run each line one by one... after all is done.. you have restored factory image...
End of part 1 Part 2 at Next Post
Reactions: anon(1039967)
Continue part 2- How to root?
Now to root it download clockwordmod from here ClockworkMod ROM Manager - Recoveries
look for "Google Galaxy Nexus (GSM)" recovery or touch recovery.
place it in the same folder "c:\programfiles...........\sdk..."
in the same command prompt run "fastboot flash recovery [downloaded clockworkmod filename].img"
replace the filename of clockworkmod above...
Download root from here Superuser
ARM devices (2.0 – 4.1)
3.1.3
place the superuser file in the phones sdcard
after that go to clockworkmod recovery in phone and install file from sdcard-->[go to location of file]-->Install and click yes.
you are done. rooted.
r3dpuk3
