Results 1 to 22 of 22
    Default Google Cards not working Galaxy Nexus
    A question for any pros out there, I have a Google galaxy nexus ( from Google). The Google now works as far as voice recognition and asking questions, however cards are not displayed and at the bottom of the Google now screen I do not have a area that is supposed to have "more Google cards" button. I have activated everything I can think of and cards still do not display. I even allowed google to save web searches on my account ( its active). It also said to tap in the Google now window go to settings and then "Google now" to turn on or off....well I do not have a "Google now" option....strange! Can anyone tell me what it might be? I would love to have the rest of the feature.
    thanks in advance if anyone can figure this out.
    I am on 4.1 Jelly Bean ( did not root ) its standard upgrade.
  2. #2
    Default Re: Google Cards not working Galaxy Nexus
    that is really weird... can you try to clear data and cache for google now and try to set the app again. it might fix itself.
    I will give that a shot. Thanks I was not sure if the app was integrated into the device.
  4. #4
    The App is "Google Search" Try clearing "Voice search" cache/Data as well.
    its an app integrated to the OS.
    The app associated with Google now says "Google Search" in the All apps info, however after I deleted the icon the google now window stayed there. It does not act like seperate app.
  6. #6
    Quote Originally Posted by Entouchman View Post
    deleted the icon?? I am confused. Can you explain the second part? if you are deleting the data/Cache how do you see google now window?
    I moved the "google search" app to trash and cleared cache from apps>all>google search, cleared data and cache. thats what I was saying sorry.
  8. #8
    try clearing data for "Voice search" as well. Then try setting google now again.
    I cannot find voice search as an app in the Settings>Apps however I do have an icon on my phone screen, where do you delete cache for this?
  10. #10
    I would be "com.Google.Android.Voice"
    I thought it would be voice search but apparently not
  11. Thread Author  Thread Author    #11
    it says it will be deleted permanently, If I do this how do I recover it
  12. Thread Author  Thread Author    #12
    Wait I am sorry it said the settings etc. sorry fingers too fast for brains
  13. #13
    do not delete anything... just clear data...thats it.
  14. Thread Author  Thread Author    #14
    I did just clear data and cache, now what I search for is below the google search bar, however it is not in the form of cards and there is not the option of More cards in the bottom of that page. Also in the settings of that page the 3 dots there is no reference to Google now like the videos show, so it seems google now is not set up 100%. Again the search engine and voice search work ok it talks back when you ask a question is just does not give me cards.
  15. #15
    you dont see a google now setting at all?
    do you see this app in app drawer "Google" with G symbol?
  16. Thread Author  Thread Author    #16
    Nope no google now setting, in app drawer the G symbol is there and it says google search
  17. #17
    It should say "Google" at least thats what it says for me on my Nexus S.
    Not sure about galaxy nexus.
    Maybe it didn't update properly.
    I know its not rooted but do you know how to factor restore?
    It will wipe all data though.. without root you can update it manually too..
  18. Thread Author  Thread Author    #18
    Does not say "Google" only google search ad its the only g icon in the app drawer under all.
    I have opened a ticket with tech support to see what they recommend, first level was stumped and are escalating it further to engineer. I am with you on a factor restore, my settings are backing up all my data so it should be pretty easy. I appreciate all your help I will keep you informed on what does the trick, its probably something really stupid...I have been in technology for 31 years and this kind of stuff is out of the ordinary..a check box or something stupid.
  19. Thread Author  Thread Author    #19
    Default
    OK reset the phone reloaded and still no go same thing no Google cards
  20. #20
    I'm having exactly the same problem on my nexus 7 tablet running 4.1.1. I have wiped it twice now and tested everything. Still no option for Google now in the menu. Account restore or not, still no option! Would love to hear what they come back with...
  21. #21
    I had this same problem until I enabled my personal GMail account on my device. E.g. My Now is associated with my personal GMail account on my Nexus 7 instead of my business GMail account. With the Galaxy Nexus, I had only my business GMail account configured at first, and Now didn't work at all. When I added my personal GMail account and cleared the data on Search, then the Now cards started to appear. It is as though my association of Now on my Nexus 7 with my personal account disabled Now for my business account (and hence not working on the Galaxy Nexus). Weird, but that's what seemed to be the case.
  22. #22
    Hi,
    I have the exact same problem. I just updated my HTC One X to Jelly Bean and Google Now only shows my latest searches, no cards whatsoever. When i use voice search and ask for the weather I get a card but if I turn of and start Google Now the card is gone. I enabled everything and I cleared the cache in Google search and voice but no cards.
    I have a regular gmail account.
    Help
