Results 1 to 4 of 4
    Jacques's Avatar
    Greetings, program!
    Posts
    Global Posts
    305 Global Posts
    ROM
    Cyanogenmod 10.1 nightly
    Default Anyone have issues logging in thru Tapatalk?
    Seems that when I try to access Android Central the last day or so (either wifi or 3G/4G/LTE), it gives me the message "Request function does not exist!", then it tries to load but I get a blank white screen. I tried other forums on the app, and it loads just fine. I even cleared the cache and history on the app, and same result.
    I'm an a Samsung Galaxy SII Skyrocket with stock ICS (4.04).
  2. #2
    Default
    Yes,I went back to using AC app a little over month ago because of the issues I was having. I'm not having any more issues.:thumbup:
    sent from Evo4GLTE on AC forums
    Thanked by:
    Jacques's Avatar
    Greetings, program!
    Posts
    Global Posts
    305 Global Posts
    ROM
    Default Re: Anyone have issues logging in thru Tapatalk?
    There's an Android Central app?! Looking for that now!
  4. #4
    Default
    I just started. Haveing this issue but now it working again
    Sent from my paranoid S3
