Results 1 to 4 of 4
    Default help! phone keeps waking up randomly
    I have a samsung galaxy s3 and im loving it but my phone keeps waking up randomly. I erased most my apps and still keeps waking up. Anyone have the same problem?
  2. #2
    Default Re: help! phone keeps waking up randomly
    when you say keeps waking up what do you mean? Display wakes up?
    there is a feature in s3 called smart stay. Have you looked in to those settings?
    Yes the display is in sleep mode then wakes up. I turned off the smart stay but still keeps on turning on.
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    This happens randomly on my X2, maybe once a week. I never really concerned myself with it, but, would be curious as well if anyone has any insight.
    How often is this happening to you?
