Exactly when does Google Navigation use cellular data? Is it only when "loading" the route or does it use it throughout, while driving? I know "offline" mapping relies soley on GPS to get you around.
Hypothetically, if I were able to load directions using wifi before getting in the car, and would I use any data?
Just curious about how this works
Sent from my HTC One X using Android Central Forums
