Results 1 to 7 of 7
    Default Galaxy 8.9 stuck downloading...
    I have no idea what's going on here. I opened up my tablet and it's just been stuck on this screen for a few hours. I hadn't used it in 2 days and this was the first thing that came up when I hit "power".
    Attachment 35216
    Attachment 35218
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  2. #2
    Default Re: Galaxy 8.9 stuck downloading...
    Did the battery drain? I've been charging mine every day!
    Default
    I don't think so to be honest.
    I just realized that second picture came up blurry.
    Here's what the text on the screen says:
    "Odin download mode (protocol v3.1)"
    " reason: force key
    Secure mode: secure
    Check signature: check
    Custom binary mode: no (0 counts)
    Current binary:Samsung official
    Waiting usb cable......"
    Like I said earlier, I have no idea what is going on here . Help anyone?
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    Is it still stuck there? I'm not saying do this, because I'm not sure what the ramifications would be, but, have you done a battery pull? If you have, did it successfully boot? If not, does it just get stuck on these screens again? If so, can you access the boot menu and try and do a reset?
  5. #5
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    And don't press any keys while it's booting up.
  6. #6
    gracias
  7. #7
    I use my tablet every day. In the middle of a game today, it shut off. For about an hour, it cycled on and off. Finally, I got the same screen shown above. I thought maybe it was trying to upgrade to JellyBean, so I downloaded Samsung Kies and hooked it to my laptop. It then said, "Connected! Press the [Start] of Odin3!!" Nothing works. Please help.
