1. Pingala's Avatar
    Folks, I have a problem updating 4.0.4 to 4.1.1. The automatic update, when selected "start install", it boots and stucks at Android icon with ! mark in a traingle. My Xoom wifi runs with Kernel version: 2.6.39.4-g42a0480 & build Number: IMM76
    I would appreciate if someone could help!!
    Thanks in advance,
    Pingala
    08-23-2012 07:09 AM
  2. gurke0123's Avatar
    Hi,
    I have exactly the same problem. Any tips?
    08-25-2012 12:48 PM
  3. Wayland Beavers's Avatar
    @ Pingla and gurke0123 I have the same problem did you find a fix?
    11-08-2012 03:35 PM
  4. Devinator's Avatar
    If you are not rooted and trying to get the OTA, but, it's not working, contact the Manufacturer.
    11-09-2012 09:29 AM
