Results 1 to 7 of 7
- 08-24-2012, 01:46 PM
Thread Author #1
- 08-24-2012, 02:52 PM #2
Re: Nexus updates on Sprint / Verizon
That article pretty much explains why they delay the update... Google is not to blame here. its Verizon and sprint and their proprietary binaries.
- 08-24-2012, 03:08 PM #3
And it always will be, regardless of the phone. If you want rapid updates use the GSM version of the phone and AT&T or T-Mobile (or an MVNO that uses one of those networks). Verizon has been slow on updates from the moment OTA updates came out.
- 08-24-2012, 03:39 PM
Thread Author #4
The proprietary binaries being the radio drivers?
both phones (I don't have on so I'm assuming) are vanilla android without carrier apps, so I'm the radios must be the problem. Is that what you are assuming or is this a fact?
I guess I'm hoping Google play will have a device you can purchase that will work on sprints CDMA network. - 08-27-2012, 02:28 PM #5
- 08-28-2012, 07:27 PM #6
- 08-28-2012, 07:28 PM #7
Yup, Verizon has specific binaries as well as their own baseband which must be tested according to their procedures. Which, in all honesty, is reasonable--it's their network and their FCC license(s) at issue.
Former moderator & advisor.
HTC - the One to rule them all.
Reply
